[fdo-trac] #385: Arcsde personal/workgroup support
FDO trac_fdo at osgeo.org
Mon Aug 25 15:01:35 EDT 2008
   Reporter:  ebnesom      |       Owner:  gregboone
       Type:  enhancement  |      Status:  new
   Priority:  major        |   Milestone:  3.4.0
  Component:  FDO API      |     Version:  3.2.0
   Severity:  3            |    Keywords:  sde, workgroup, sqlexpress
External_id:               |
 9.2 provided an install of sqlexpress and sde personal or workgroup. I
 have attempted to connect to an operating workgroup sqlexpress geodatabase
 from map3d2009 but unable to connect. This uses a differnt connection type
 in arccatalog (GIS server) and doesn't seem to have a giomgr process
 running. Don't know if this is do-able with the existing sde librearies
 but it would be nice to use map at this level. Side note. I have two
 sqlexpress instances running but anable to connect to either one using the
 sqlserver provider.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/385>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
