[fdo-trac] #262: Reduce order dependencies in SchemaMgrTests.TestSpatialContexts
FDO trac_fdo at osgeo.org
Wed Feb 20 13:04:35 EST 2008
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  enhancement    |      Status:  new
   Priority:  minor          |   Milestone:  3.3.0
  Component:  FDO API        |     Version:  3.3.0
   Severity:  3              |    Keywords:
External_id:                 |
 This ticket will add the ability to do some extra processing to the output
 files generated by the abovementioned test. Some providers may reverse-
 engineer spatial contexts, from non-FDO datastores, in an unpredictable
 order, meaning that the spatial contexts in the output files are not in a
 predictable order. This leads to false failures when these files are
 compared against the masters.
 The solution will be to add a stylesheet that removes the contents of each
 spatial contexts and pastes it into each referencing geometric property.
 This gets the contents of the output files back to a predictable order.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/262>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
