[fdo-trac] #265: Schema Manager generates exception when unique constraint column not found
FDO trac_fdo at osgeo.org
Thu Feb 28 14:34:52 EST 2008
   Reporter:  brentrobinson     |       Owner:  brentrobinson
       Type:  defect            |      Status:  new
   Priority:  critical          |   Milestone:  3.3.0
  Component:  GenericRdbms API  |     Version:  3.3.0
   Severity:  1                 |    Keywords:  unique constraint hidden column exception
External_id:                    |
 Some RDBMS's have hidden columns, which can have unique constraints. These
 unique constraints cause the Schema Manager to try to put a NULL object
 into a collection.
 The fix will be to skip these unique constraints when loading them from
 the RDBMS.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/265>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
