[fdo-trac] #265: Schema Manager generates exception when unique constraint column not found
FDO trac_fdo at osgeo.org
Thu Feb 28 16:07:06 EST 2008
 Reporter:  brentrobinson                              |         Owner:  brentrobinson
     Type:  defect                                     |        Status:  closed
 Priority:  critical                                   |     Milestone:  3.3.0
Component:  GenericRdbms API                           |       Version:  3.3.0
 Severity:  1                                          |    Resolution:  fixed
 Keywords:  unique constraint hidden column exception  |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 3781
 Author: brentrobinson
 Date: 3:39:11 PM, Thursday, February 28, 2008
 Message:
 Ticket#265: Skip loading unique constraints on hidden columns.
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/265#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
