[fdo-trac] #244: FDOGeometricType not exposed in DotNET API
    trac_fdo at osgeo.org
    Mon Jan 28 14:52:48 EST 2008
 Reporter:  chrisErickson  |         Owner:  gregboone
     Type:  defect         |        Status:  new
 Priority:  minor          |     Milestone:  3.3.0
Component:  FDO API        |       Version:  3.2.0
 Severity:  3              |    Resolution:
 Keywords:                 |   External_id:
Comment (by chrisErickson):
 As an addition to this, when passing Enumerations that are bitwise in a
 DotNet API, you can still use the Enum name in the signature rather than
 casting it to an int.  This makes the API much more friendly, especially
 when there are similarly named enumerations.
 For instance:
 with a given enum of:
 public enum GeometricType
     GeometricType_Point = 1,
     GeometricType_Curve = 2,
     GeometricType_Surface = 4,
     GeometricType_Solid = 8,
 The signature for
 int GeometricPropertyDefinition::GeometryTypes
 could be:
 GeometryType GeometricPropertyDefinition::GeometryTypes
 and GeometryTypes can return GeometricType_Solid | GeometricType_Surface
 Similarly,
 void GeometricPropertyDefinition::set_SpecificGeometryTypes(GeometryType[]
 types, int length)
 could be
 types)
 and the user could hand in
 GeometricPropertyDefinition::set_SpecificGeometryTypes(GeometricType_Solid
 | GeometricType_Surface)
Ticket URL: <http://trac.osgeo.org/fdo/ticket/244#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac
