[fdo-trac] #350: SQLite provider: crash when getting geometry using a Select before a DerscribeSchema
FDO trac_fdo at osgeo.org
Tue Jun 17 12:38:29 EDT 2008
DerscribeSchema
   Reporter:  traianstanev     |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  minor            |   Milestone:
  Component:  SQLite Provider  |     Version:  3.3.0
   Severity:  3                |    Keywords:
External_id:                   |
 An exception gets thrown by the FdoIFeatureReader::GetGeometry()
 implementation in the provider, in cases where a Select is done without a
 DescribeSchema having been done with the same connection. The reason was
 that the geometry encoding type of the geometry column does not get
 initialized until the time FdoFeatureClasses are created for
 DescribeSchema purposes (i.e. initialization of the geom encoding type is
 way too lazy).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/350>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
