[fdo-trac] #352: ArcSDE 9.2 globalid field type support
FDO trac_fdo at osgeo.org
Sat Jun 28 00:45:55 EDT 2008
   Reporter:  ebnesom          |       Owner:  gregboone
       Type:  enhancement      |      Status:  new
   Priority:  major            |   Milestone:
  Component:  ArcSDE Provider  |     Version:  3.3.0
   Severity:  5 (Wish List)    |    Keywords:
External_id:                   |
 There is a globalid type field that is required for database replication.
 This adds very robust support for field operations. however with the
 limited capability I have and the limited test environment arcmap/autocad
 map/mapguide 6.5, I can only provide information about what I have seen
 and experienced. In Map 2009 (fdo 3.3 I think ships with) out of the box,
 I can go right up to the point of checking in. at which point I get an
 error null value not allowed. I then experience problems removing the
 incomplete object from the edit set. After removing the global id field
 and adding a new feature (while still recieving the message of the edit
 set not being empty) I am able to check in the new feature and it seems to
 fix the incomplete feature. Not sure this is true.
 possibly info for a diffferent track but geodatabase domainns do not
 enforced and are not discoverable.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/352>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
