[fdo-trac] #280: Errors with Linux FDO?
FDO trac_fdo at osgeo.org
Tue Mar 25 02:42:45 EDT 2008
   Reporter:  Rothgar         |       Owner:  gregboone
       Type:  defect          |      Status:  new
   Priority:  critical        |   Milestone:  3.3.1
  Component:  MySQL Provider  |     Version:  3.3.0
   Severity:  1               |    Keywords:
External_id:                  |
 I am currently running the 3.3.0 FDO's from the package available on the
 website, I will try and etst the SVN soon.
 Here are the error messages:
 CLNT_8_UNABLE_TO_LOAD_LIBRARY
 Exception occurred in method MgFdoConnectionManager.Open at line 377 in
 file FdoConnectionManager.cpp
 (2725579664) An exception occurred in FDO component.
 (2708794256) An exception occurred in FDO component.
 Exception occurred in method MgFdoConnectionManager.Open at line 262 in
 (2700401552) An exception occurred in FDO component.
 (2683616144) An exception occurred in FDO component.
 (2675223440) An exception occurred in FDO component.
 (2608081808) An exception occurred in FDO component.
 (2599689104) An exception occurred in FDO component.
 (2750757776) An exception occurred in FDO component.
 (2742365072) An exception occurred in FDO component.
 (2692008848) An exception occurred in FDO component.
 (2666830736) An exception occurred in FDO component.
 (2658438032) An exception occurred in FDO component.
 We are trying to connect from MapGuide Studio 2009 Beta and when we try to
 make a new MySQL conenction all we get is the "Service" textbox, the
 credentials are greyed out. If you enter the IP address and click "Test
 connection" you get the error:
 An exception occurred in FDO component. CLNT_8_UNABLE_TO_LOAD_LIBRARY
 We had a Windows OpenSourceMapGuide install on Windows and that worked
 fine with MapGuide Studio 2009.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/280>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
