[fdo-trac] #280: Errors with Linux FDO?
FDO trac_fdo at osgeo.org
Tue Mar 25 17:47:23 EDT 2008
 Reporter:  Rothgar         |         Owner:  gregboone
     Type:  defect          |        Status:  new
 Priority:  critical        |     Milestone:  3.3.0
Component:  MySQL Provider  |       Version:  3.3.0
 Severity:  1               |    Resolution:
 Keywords:                  |   External_id:
Comment (by Rothgar):
 Hmm you might be correct:
 My providers.xml contains:
   <FeatureProvider>
     <Name>OSGeo.MySQL.3.3</Name>
     <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>
     <Description>FDO Provider for MySql</Description>
     <IsManaged>False</IsManaged>
     <Version>3.3.0.0</Version>
     <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
     <LibraryPath>/usr/local/fdo-3.3.0/lib/libFdoMySQL.so</LibraryPath>
   </FeatureProvider>
 root at mapsrv:/home/jasonm# ls -al /usr/local/fdo-3.3.0/lib/libFdoMySQL.so
 ls: /usr/local/fdo-3.3.0/lib/libFdoMySQL.so: No such file or directory
 I used the rdbms, I'll try re-install the FDO and if that doesn't work
 I'll try the SVN.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/280#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
