[fdo-trac] #280: Errors with Linux FDO?
FDO trac_fdo at osgeo.org
Tue Mar 25 20:27:43 EDT 2008
 Reporter:  Rothgar         |         Owner:  gregboone
     Type:  defect          |        Status:  new
 Priority:  critical        |     Milestone:  3.3.0
Component:  MySQL Provider  |       Version:  3.3.0
 Severity:  1               |    Resolution:
 Keywords:                  |   External_id:
Comment (by Rothgar):
 Alright ran into a few errors...
 I didn't have the unixODBC installed because I don't want to use ODBC only
 MySQL. I didn't get any stop error message about this when running
 "build_thirdparty" and "build_oem"
 I saw a number of errors with bzip2?:
 libs/iostreams/src/bzip2.cpp:29: error: âBZ_OKâ was not declared in this
 scope
 libs/iostreams/src/bzip2.cpp:30: error: âBZ_RUN_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:31: error: âBZ_FLUSH_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:32: error: âBZ_FINISH_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:33: error: âBZ_STREAM_ENDâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:34: error: âBZ_SEQUENCE_ERRORâ was not
 declared in this scope
 libs/iostreams/src/bzip2.cpp:35: error: âBZ_PARAM_ERRORâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:36: error: âBZ_MEM_ERRORâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:37: error: âBZ_DATA_ERRORâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:38: error: âBZ_DATA_ERROR_MAGICâ was not
 libs/iostreams/src/bzip2.cpp:39: error: âBZ_IO_ERRORâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:40: error: âBZ_UNEXPECTED_EOFâ was not
 libs/iostreams/src/bzip2.cpp:41: error: âBZ_OUTBUFF_FULLâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:42: error: âBZ_CONFIG_ERRORâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:46: error: âBZ_FINISHâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:47: error: âBZ_RUNâ was not declared in this
 scope
 libs/iostreams/src/bzip2.cpp: In static member function âstatic void
 boost::iostreams::bzip2_error::check(int)â:
 libs/iostreams/src/bzip2.cpp:60: error: âBZ_OKâ was not declared in this
 scope
 libs/iostreams/src/bzip2.cpp:61: error: âBZ_RUN_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:62: error: âBZ_FLUSH_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:63: error: âBZ_FINISH_OKâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:64: error: âBZ_STREAM_ENDâ was not declared
 in this scope
 libs/iostreams/src/bzip2.cpp:66: error: âBZ_MEM_ERRORâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp: In constructor
 âboost::iostreams::detail::bzip2_base::bzip2_base(const
 boost::iostreams::bzip2_params&)â:
 libs/iostreams/src/bzip2.cpp:78: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:78: error: expected `)' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp: In destructor
 âboost::iostreams::detail::bzip2_base::~bzip2_base()â:
 libs/iostreams/src/bzip2.cpp:81: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:81: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:81: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:81: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:81: error: expected primary-expression before
 â>â token
 libs/iostreams/src/bzip2.cpp:81: error: expected `)' before â;â token
 libs/iostreams/src/bzip2.cpp: In member function âvoid
 boost::iostreams::detail::bzip2_base::before(const char*&, const char*,
 char*&, char*)â:
 libs/iostreams/src/bzip2.cpp:86: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:86: error: âsâ was not declared in this scope
 libs/iostreams/src/bzip2.cpp:86: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:86: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:86: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:86: error: expected primary-expression before
 â>â token
 libs/iostreams/src/bzip2.cpp:86: error: expected `)' before â;â token
 boost::iostreams::detail::bzip2_base::after(const char*&, char*&)â:
 libs/iostreams/src/bzip2.cpp:95: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:95: error: âsâ was not declared in this scope
 libs/iostreams/src/bzip2.cpp:95: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:95: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:95: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:95: error: expected primary-expression before
 â>â token
 libs/iostreams/src/bzip2.cpp:95: error: expected `)' before â;â token
 boost::iostreams::detail::bzip2_base::end(bool)â:
 libs/iostreams/src/bzip2.cpp:103: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:103: error: âsâ was not declared in this
 scope
 libs/iostreams/src/bzip2.cpp:103: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:103: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:103: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:103: error: expected primary-expression
 before â>â token
 libs/iostreams/src/bzip2.cpp:103: error: expected `)' before â;â token
 libs/iostreams/src/bzip2.cpp:106: error: âBZ2_bzCompressEndâ was not
 libs/iostreams/src/bzip2.cpp:107: error: âBZ2_bzDecompressEndâ was not
 libs/iostreams/src/bzip2.cpp: In member function âint
 boost::iostreams::detail::bzip2_base::compress(int)â:
 libs/iostreams/src/bzip2.cpp:113: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:113: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:113: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:113: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:113: error: expected primary-expression
 before â>â token
 boost::iostreams::detail::bzip2_base::decompress()â:
 libs/iostreams/src/bzip2.cpp:118: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:118: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:118: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:118: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:118: error: expected primary-expression
 before â>â token
 boost::iostreams::detail::bzip2_base::do_init(bool, void* (*)(void*, int,
 int), void (*)(void*, void*), void*)â:
 libs/iostreams/src/bzip2.cpp:129: error: âbz_streamâ was not declared in
 this scope
 libs/iostreams/src/bzip2.cpp:129: error: âsâ was not declared in this
 scope
 libs/iostreams/src/bzip2.cpp:129: error: expected type-specifier before
 âbz_streamâ
 libs/iostreams/src/bzip2.cpp:129: error: expected `>' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:129: error: expected `(' before âbz_streamâ
 libs/iostreams/src/bzip2.cpp:129: error: expected primary-expression
 before â>â token
 libs/iostreams/src/bzip2.cpp:129: error: expected `)' before â;â token
 libs/iostreams/src/bzip2.cpp:146: error: âBZ2_bzCompressInitâ was not
 libs/iostreams/src/bzip2.cpp:149: error: âBZ2_bzDecompressInitâ was not
 It didn't stop though. I still didn't have the MySQL lib after re-
 installing the FDO. I ran "./build_linux.sh --w rdbms" and then got a stop
 error message about ODBC?
 I then installed the unixODBC and unixODBC-dev and got further, I guess
 the README should be changed to say you need the MySQL and ODBC libraries
 if you want to use RDBMS?
 the thing that is strange is why didn't it throw an error before now?
 root at mapsrv:/home/fdo-src/OpenSource_FDO# ./build_linux.sh --help
 build_linux.sh [--h]
                [--c BuildType]
                [--a Action]
                [--w WithModule]
                [--d BuildDocs]
                [--m ConfigMakefiles]
 Help:            --h[elp]
 BuildType:       --c[onfig] release(default), debug
 Action:          --a[ction] buildinstall(default), build, install,
 uninstall, clean
 BuildDocs:       --d[ocs] skip(default), build
 ConfigMakefiles: --m[akefile] configure(default), noconfigure
 WithModule:      --w[ith] all(default), fdocore, fdo, utilities,
 providers, shp, sdf, gdal, rdbms, ogr
 It says the default is "--w all" ?
 In any case the new error message I receive is:
 make[3]: Entering directory `/home/fdo-
 src/OpenSource_FDO/Providers/GenericRdbms/Src/UnitTest'
 /bin/sh ../../libtool --tag=CXX --mode=link g++  -O2 -MMD -MT  -D__USE_GNU
 -DLINUX -DLINUX_IA32 -D__STDC_LIMIT_MACROS -DRDBI_STATIC   -o UnitTestOdbc
 -L/usr/lib OdbcTestRegister.o -lxalan-c -lxalanMsg -lxerces-c -lz -lodbc
 ./Common/libCommonUnitTests.la ./Odbc/libOdbcUnitTests.la
 ../ODBC/libFdoRdbmsODBC.la ../Fdo/libFdoRdbms.la ../Rdbi/librdbi.la
 ../ODBCDriver/libFdoODBCDriver.la ../Gdbi/libGdbi.la
 ../LongTransactionManager/libLTManager.la ../LockManager/libLockManager.la
 ../Util/libutil.la ../Geometry/Fgf/libgeometry_fgf.la
 ../SchemaMgr/Lp/libSmLpGrd.la ../SchemaMgr/libSmGrd.la
 ../SchemaMgr/Ov/libSchemaMgr_OV.la ../SchemaMgr/Ph/Cfg/libSmPhCfgGrd.la
 ../SchemaMgr/Ph/libSmPhGrd.la ../SchemaMgr/Ph/Rd/libSmPhRdGrd.la
 ../ODBC/SchemaMgr/Ph/Rd/libFdoRdbmsODBC_SchemaMgr_Ph_Rd.la /home/fdo-
 src/OpenSource_FDO/Fdo/Unmanaged/Src/libFDO.la /home/fdo-
 src/OpenSource_FDO/Thirdparty/linux/cppunit/lib/libcppunit.a /home/fdo-
 src/OpenSource_FDO/Utilities/Common/libProvidersCommon.la /home/fdo-
 src/OpenSource_FDO/Utilities/TestCommon/libTestCommon.la /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/libSchemaMgr.la /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Lp/libSmLogicalPhysical.la
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/libSmPhysical.la /home/
 fdo-src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Cfg/libSmPhCfg.la
 /home/fdo-src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Mt/libSmPhMt.la
 /home/fdo-src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Rb/libSmPhRb.la
 /home/fdo-src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Rd/libSmPhRd.la
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ov/libSmOverrides.la /home/
 fdo-
 src/OpenSource_FDO/Utilities/ExpressionEngine/Src/libExpressionEngine.la
 /home/fdo-src/OpenSource_FDO/Utilities/Common/libProvidersCommon.la
 ../Rdbi/librdbi.la ../Util/libutil.la -lodbc -lz
 g++ -O2 -MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -D__STDC_LIMIT_MACROS
 -DRDBI_STATIC -o .libs/UnitTestOdbc OdbcTestRegister.o  -L/usr/lib
 ./Common/.libs/libCommonUnitTests.a ./Odbc/.libs/libOdbcUnitTests.a
 ../ODBC/.libs/libFdoRdbmsODBC.a ../Fdo/.libs/libFdoRdbms.a
 ../ODBCDriver/.libs/libFdoODBCDriver.a ../Gdbi/.libs/libGdbi.a
 ../LongTransactionManager/.libs/libLTManager.a
 ../LockManager/.libs/libLockManager.a
 ../Geometry/Fgf/.libs/libgeometry_fgf.a ../SchemaMgr/Lp/.libs/libSmLpGrd.a
 ../SchemaMgr/.libs/libSmGrd.a ../SchemaMgr/Ov/.libs/libSchemaMgr_OV.a
 -L/home/fdo-src/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/lib -L/home/
 fdo-src/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/lib -lxalan-c
 -lxalanMsg -lxerces-c -lpthread -ldl
 ../SchemaMgr/Ph/Cfg/.libs/libSmPhCfgGrd.a
 ../SchemaMgr/Ph/.libs/libSmPhGrd.a ../SchemaMgr/Ph/Rd/.libs/libSmPhRdGrd.a
 ../ODBC/SchemaMgr/Ph/Rd/.libs/libFdoRdbmsODBC_SchemaMgr_Ph_Rd.a /home/fdo-
 src/OpenSource_FDO/Fdo/Unmanaged/Src/.libs/libFDO.so /home/fdo-
 src/OpenSource_FDO/Utilities/TestCommon/.libs/libTestCommon.a /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/.libs/libSchemaMgr.a /home/
 fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Lp/.libs/libSmLogicalPhysical.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/.libs/libSmPhysical.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Cfg/.libs/libSmPhCfg.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Mt/.libs/libSmPhMt.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Rb/.libs/libSmPhRb.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ph/Rd/.libs/libSmPhRd.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/SchemaMgr/Src/Sm/Ov/.libs/libSmOverrides.a
 /home/fdo-
 src/OpenSource_FDO/Utilities/ExpressionEngine/Src/.libs/libExpressionEngine.so
 /home/fdo-src/OpenSource_FDO/Utilities/Common/.libs/libProvidersCommon.a
 ../Rdbi/.libs/librdbi.a ../Util/.libs/libutil.a /usr/lib/libodbc.so -lz
 -Wl,--rpath -Wl,/usr/local/fdo-3.3.0/lib
 /usr/bin/ld: warning: libxalanMsg.so.17, needed by /home/fdo-
 src/OpenSource_FDO/Fdo/Unmanaged/Src/.libs/libFDO.so, may conflict with
 libxalanMsg.so.110
 /usr/bin/ld: warning: libxerces-c.so.25, needed by /home/fdo-
 libxerces-c.so.27
 ../ODBC/.libs/libFdoRdbmsODBC.a(FdoRdbmsOdbcConnection.o): In function
 `FdoRdbmsOdbcConnection::GetSchemaNameFromDsn()':
 FdoRdbmsOdbcConnection.cpp:(.text+0x1cc4): undefined reference to
 `SQLGetPrivateProfileString'
 /home/fdo-src/OpenSource_FDO/Fdo/Unmanaged/Src/.libs/libFDO.so: undefined
 reference to `xalanc_1_7::XalanTransformer::terminate()'
 reference to
 `xalanc_1_7::XalanTransformer::transform(xalanc_1_7::XSLTInputSource
 const&, xalanc_1_7::XSLTInputSource const&, void*, unsigned int (*)(char
 const*, unsigned int, void*), void (*)(void*))'
 reference to `xalanc_1_7::XalanDOMString::transcode() const'
 reference to `xalanc_1_7::XalanTransformer::~XalanTransformer()'
 reference to `xalanc_1_7::XalanTransformer::initialize()'
 reference to
 `xalanc_1_7::XalanTransformer::setStylesheetParam(xalanc_1_7::XalanDOMString
 const&, xalanc_1_7::XalanDOMString const&)'
 reference to `typeinfo for xalanc_1_7::XSLException'
 reference to `typeinfo for xalanc_1_7::ProblemListener'
 reference to `xalanc_1_7::XalanDOMString::XalanDOMString(char const*,
 unsigned int)'
 reference to `xalanc_1_7::ProblemListener::ProblemListener()'
 reference to `xalanc_1_7::XSLTInputSource::XSLTInputSource()'
 reference to `typeinfo for xalanc_1_7::XSLTInputSource'
 reference to `vtable for xalanc_1_7::XSLTInputSource'
 reference to `xalanc_1_7::XalanTransformer::XalanTransformer()'
 reference to `xalanc_1_7::ProblemListener::~ProblemListener()'
 collect2: ld returned 1 exit status
 make[3]: *** [UnitTestOdbc] Error 1
 make[3]: Leaving directory `/home/fdo-
 make[2]: *** [install-recursive] Error 1
 make[2]: Leaving directory `/home/fdo-
 make[1]: *** [install-recursive] Error 1
 make[1]: Leaving directory `/home/fdo-
 src/OpenSource_FDO/Providers/GenericRdbms/Src'
 make: *** [install-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/fdo/ticket/280#comment:5>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
