[fdo-trac] #280: Errors with Linux FDO?
FDO trac_fdo at osgeo.org
Wed Mar 26 18:15:30 EDT 2008
 Reporter:  Rothgar         |         Owner:  gregboone
     Type:  defect          |        Status:  new
 Priority:  critical        |     Milestone:  3.3.0
Component:  MySQL Provider  |       Version:  3.3.0
 Severity:  1               |    Resolution:
 Keywords:                  |   External_id:
Comment (by Rothgar):
 If I remove libxalan and libxerces from the system and try to use the ones
 in the FDO SVN I get a different error:
 make[3]: Entering directory `/home/fdo-
 svn/fdosvn/Providers/GenericRdbms/Src/UnitTest'
 /bin/sh ../../libtool --tag=CXX --mode=link g++  -O2 -MMD -MT  -D__USE_GNU
 -DLINUX -DLINUX_IA32 -D__STDC_LIMIT_MACROS -DRDBI_STATIC   -o UnitTestOdbc
 -L/usr/lib OdbcTestRegister.o -lxalan-c -lxalanMsg -lxerces-c -lz -lodbc
 ./Common/libCommonUnitTests.la ./Odbc/libOdbcUnitTests.la
 ../ODBC/libFdoRdbmsODBC.la ../Fdo/libFdoRdbms.la ../Rdbi/librdbi.la
 ../ODBCDriver/libFdoODBCDriver.la ../Gdbi/libGdbi.la
 ../LongTransactionManager/libLTManager.la ../LockManager/libLockManager.la
 ../Util/libutil.la ../Geometry/Fgf/libgeometry_fgf.la
 ../SchemaMgr/Lp/libSmLpGrd.la ../SchemaMgr/libSmGrd.la
 ../SchemaMgr/Ov/libSchemaMgr_OV.la ../SchemaMgr/Ph/Cfg/libSmPhCfgGrd.la
 ../SchemaMgr/Ph/libSmPhGrd.la ../SchemaMgr/Ph/Rd/libSmPhRdGrd.la
 ../ODBC/SchemaMgr/Ph/Rd/libFdoRdbmsODBC_SchemaMgr_Ph_Rd.la /home/fdo-
 svn/fdosvn/Fdo/Unmanaged/Src/libFDO.la /home/fdo-
 svn/fdosvn/Thirdparty/linux/cppunit/lib/libcppunit.a /home/fdo-
 svn/fdosvn/Utilities/Common/libProvidersCommon.la /home/fdo-
 svn/fdosvn/Utilities/TestCommon/libTestCommon.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/libSchemaMgr.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Lp/libSmLogicalPhysical.la /home/
 fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/libSmPhysical.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Cfg/libSmPhCfg.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Mt/libSmPhMt.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Rb/libSmPhRb.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Rd/libSmPhRd.la /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ov/libSmOverrides.la /home/fdo-
 svn/fdosvn/Utilities/ExpressionEngine/Src/libExpressionEngine.la /home/
 fdo-svn/fdosvn/Utilities/Common/libProvidersCommon.la ../Rdbi/librdbi.la
 ../Util/libutil.la -lodbc -lz
 g++ -O2 -MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -D__STDC_LIMIT_MACROS
 -DRDBI_STATIC -o .libs/UnitTestOdbc OdbcTestRegister.o  -L/usr/lib
 ./Common/.libs/libCommonUnitTests.a ./Odbc/.libs/libOdbcUnitTests.a
 ../ODBC/.libs/libFdoRdbmsODBC.a ../Fdo/.libs/libFdoRdbms.a
 ../ODBCDriver/.libs/libFdoODBCDriver.a ../Gdbi/.libs/libGdbi.a
 ../LongTransactionManager/.libs/libLTManager.a
 ../LockManager/.libs/libLockManager.a
 ../Geometry/Fgf/.libs/libgeometry_fgf.a ../SchemaMgr/Lp/.libs/libSmLpGrd.a
 ../SchemaMgr/.libs/libSmGrd.a ../SchemaMgr/Ov/.libs/libSchemaMgr_OV.a
 -L/home/fdo-svn/fdosvn/Thirdparty/apache/xml-xalan/c/lib -L/home/fdo-
 svn/fdosvn/Thirdparty/apache/xml-xerces/c/lib -lxalan-c -lxalanMsg
 -lxerces-c -lpthread -ldl ../SchemaMgr/Ph/Cfg/.libs/libSmPhCfgGrd.a
 ../SchemaMgr/Ph/.libs/libSmPhGrd.a ../SchemaMgr/Ph/Rd/.libs/libSmPhRdGrd.a
 ../ODBC/SchemaMgr/Ph/Rd/.libs/libFdoRdbmsODBC_SchemaMgr_Ph_Rd.a /home/fdo-
 svn/fdosvn/Fdo/Unmanaged/Src/.libs/libFDO.so /home/fdo-
 svn/fdosvn/Utilities/TestCommon/.libs/libTestCommon.a /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/.libs/libSchemaMgr.a /home/fdo-
 svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Lp/.libs/libSmLogicalPhysical.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/.libs/libSmPhysical.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Cfg/.libs/libSmPhCfg.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Mt/.libs/libSmPhMt.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Rb/.libs/libSmPhRb.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ph/Rd/.libs/libSmPhRd.a
 /home/fdo-svn/fdosvn/Utilities/SchemaMgr/Src/Sm/Ov/.libs/libSmOverrides.a
 /home/fdo-
 svn/fdosvn/Utilities/ExpressionEngine/Src/.libs/libExpressionEngine.so
 /home/fdo-svn/fdosvn/Utilities/Common/.libs/libProvidersCommon.a
 ../Rdbi/.libs/librdbi.a ../Util/.libs/libutil.a /usr/lib/libodbc.so -lz
 -Wl,--rpath -Wl,/usr/local/fdo-3.3.0/lib
 ../ODBC/.libs/libFdoRdbmsODBC.a(FdoRdbmsOdbcConnection.o): In function
 `FdoRdbmsOdbcConnection::GetSchemaNameFromDsn()':
 FdoRdbmsOdbcConnection.cpp:(.text+0x1cc4): undefined reference to
 `SQLGetPrivateProfileString'
 collect2: ld returned 1 exit status
 make[3]: *** [UnitTestOdbc] Error 1
 make[3]: Leaving directory `/home/fdo-
 make[2]: *** [install-recursive] Error 1
 make[2]: Leaving directory `/home/fdo-
 make[1]: *** [install-recursive] Error 1
 make[1]: Leaving directory `/home/fdo-
 svn/fdosvn/Providers/GenericRdbms/Src'
 make: *** [install-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/fdo/ticket/280#comment:8>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
