[fdo-trac] #404: ODBC provider - Incorrect DateTime insert (seconds are truncated)
FDO trac_fdo at osgeo.org
Mon Oct 6 17:26:40 EDT 2008
   Reporter:  danstoica      |       Owner:  danstoica
       Type:  defect         |      Status:  new
   Priority:  major          |   Milestone:  3.4.0
  Component:  ODBC Provider  |     Version:  3.2.0
   Severity:  3              |    Keywords:
External_id:  1127137        |
 The string representing the datetime is not correctly formatted on insert
 and the 'seconds' field is truncated. Example:
 Insert 10/3/2008 1:41:55. Check the feature it in and on read the value
 will come back as 10/3/2008 1:41:00
 The error is in FdoRdbmsOdbcConnection::FdoToDbiTime() where the fact
 'seconds' is a float is ignored and it is treated as an int instead.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/404>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
