[fdo-trac] #406: Improvements to the look and feel of the FDO component API reference documents.
FDO trac_fdo at osgeo.org
Tue Oct 7 09:20:23 EDT 2008
documents.
   Reporter:  donaldcameron  |       Owner:  Donald Cameron
       Type:  enhancement    |      Status:  new
   Priority:  major          |   Milestone:  3.4.0
  Component:  Documentation  |     Version:  3.3.1
   Severity:  3              |    Keywords:  API Reference
External_id:                 |
 The objective is to improve the look and feel of the API reference
 documents and to add some new reference documents. The API reference
 documents are html documents that are created by doxygen from source code
 header files, topic files (dummy .h files), and formatting files (header
 and footer html files and css files). The improvement is achieved by doing
 some processing prior to and after calling doxygen.
 The topic content is contained in files named define_pages*.h. The
 formatting files are named header*.html and footer.html. There is a common
 set of css files used for all FDO component API reference documents. They
 are osgeo.css and geospatial.css. There is an associated javascript file
 for creating the banner. It is named geospatial.js. Minor changes were
 made to the doxygen configuration files for each component. A build script
 has been written to automate the generation of the html files and their
 subsequent packaging for distribution. The first release of the documents
 in their new format is pending.
 The reference documents being added are as follows:
 1. KingOracle C++ API Reference
 2. MySQL C# API Reference
 3. PostGIS C++ API Reference
 4. SHP C# API Reference
 5. SQLServerSpatial C++ API Reference
 6. SQLServerSpatial C# API Reference
 7. WMS C# API Reference
 The first submission against this ticket will be all of the above-
 mentioned files with the exception of the CSS and javascript files and the
 build script. The second submission will contain the latter files.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/406>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
