[fdo-trac] #407: SQLite: Insert fails when fully qualified class name is used
FDO trac_fdo at osgeo.org
Thu Oct 9 10:57:57 EDT 2008
   Reporter:  traianstanev     |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:
  Component:  SQLite Provider  |     Version:  3.3.0
   Severity:  3                |    Keywords:
External_id:                   |
 This is a defect found by Philip Kast. If a fully qualified class name is
 used with an Insert command, insert will fail. Here is the description:
 [[BR]]
 BTW: I found the problem why the feature class name comes as
 “schema:feature_class_name”:
         virtual void SetFeatureClassName(FdoString* value)
             FDO_SAFE_RELEASE(m_className);
             m_className = NULL;
             if (value)
                 m_className = FdoIdentifier::Create(value);
             m_fcname = W2A_SLOW(value);
 Change it to:
             m_className = NULL;
             if (value)
                 m_fcname = W2A_SLOW(m_className->GetName());
Ticket URL: <http://trac.osgeo.org/fdo/ticket/407>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
