[fdo-trac] #399: Port SDF changes from 3.4.0 -> 3.3.x
FDO trac_fdo at osgeo.org
Tue Sep 23 13:31:39 EDT 2008
   Reporter:  gregboone     |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:
  Component:  SHP Provider  |     Version:  3.2.0
   Severity:  3             |    Keywords:
External_id:                |
 Port the following SDF changes from 3.4.0 -> 3.3.x
 Author: brentrobinson
 Date: 2008-09-17 16:44:47 -0400 (Wed, 17 Sep 2008)
 New Revision: 4081
    trunk/Providers/SDF/Src/Provider/SdfQueryOptimizer.cpp
    trunk/Providers/SDF/Src/UnitTest/MasterTest.cpp
    trunk/Providers/SDF/Src/UnitTest/MasterTest.h
    trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp
 Ticket#395:
 SDF: Fix for scenario described in ticket. The fix was to do a table scan
 in when parsed filter value's type differs from identity property.
 A table scan can be slow so more work needs to be done to optimize this
 case. However, this submission makes the select get the right result.
 Author: jacklee
 Date: 2008-08-22 14:57:45 -0400 (Fri, 22 Aug 2008)
 New Revision: 4061
 Ticket #45:Fixed Linux build
 Date: 2008-08-22 14:24:20 -0400 (Fri, 22 Aug 2008)
 New Revision: 4060
    trunk/Providers/SDF/Src/Provider/SdfQueryOptimizer.h
 Ticket#383: optimize "in" condition handling in selects.
 Author: jacklee
 Date: 2008-04-07 17:52:50 -0400 (Mon, 07 Apr 2008)
 New Revision: 3857
    trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp
 Ticket #284
 In the Close method, set m_filterExec to NULL.
 Author: badreddinekaroui
 Date: 2008-04-04 14:48:33 -0400 (Fri, 04 Apr 2008)
 New Revision: 3855
 See ticket#284
Ticket URL: <http://trac.osgeo.org/fdo/ticket/399>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
