[fdo-trac] #308: Specific MrSid images not displaying.
FDO trac_fdo at osgeo.org
Fri Apr 3 04:12:23 EDT 2009
 Reporter:  andrewd               |         Owner:  warmerdam
     Type:  defect                |        Status:  closed
 Priority:  critical              |     Milestone:
Component:  GDAL Provider         |       Version:  3.2.0
 Severity:  2                     |    Resolution:  fixed
 Keywords:  mrsid not displaying  |   External_id:
Changes (by jbirch):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Works in 2.1.  Details are in the MapGuide ticket.  The gdal provider
 behaves much better when you provide a CS for CS-less images through the
 use of a VRT, but you can also use in MapGuide natively by overriding the
 CS, and entering the map coordinates manually.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/308#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
