[fdo-trac] #495: ArcSDE
FDO trac_fdo at osgeo.org
Sat Apr 4 08:44:49 EDT 2009
#495: ArcSDE
   Reporter:  crispinatime  |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.5.0
  Component:  FDO API       |     Version:  3.4.0
   Severity:  3             |    Keywords:
External_id:                |
 In ArcSDEFeatureReader.cpp there is a section that handles an SDE error
 (in MapGuide throws to the log files) but retains the connection.
 In experience when we see "Cannot initialize SE_STREAM structure." the
 connection is then gubbed and should be closed / reopended as all future
 requests to that open connection will fail.
  Crispin
 Existing code:
  result = SE_stream_create (mConnection->GetConnection (), &mStream);
  handle_sde_err<FdoCommandException> (mConnection->GetConnection (),
 result, __FILE__, __LINE__, ARCSDE_STREAM_ALLOC, "Cannot initialize
 SE_STREAM structure.");
Ticket URL: <http://trac.osgeo.org/fdo/ticket/495>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
