[fdo-trac] #501: ODBC Provider on XLS Truncates Data
FDO trac_fdo at osgeo.org
Tue Apr 7 12:16:01 EDT 2009
   Reporter:  crispinatime  |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.4.0
  Component:  FDO API       |     Version:  3.3.2
   Severity:  3             |    Keywords:
External_id:                |
 Sample XLS file attached.  I cannot get the ODBC reader to get beyond a
 certain 'difficult' row.  Inserting records at some places in the XLS is
 OK, but anything at the end will not show - a featureReader only gets to
 row 11!
 The data was originally part of a much larger XLS but I removed hundreds
 of records to get down to this simple test case.
 This manifests in 3.3 and 3.4.  I also think there may be an issue with
 3.4 not freeing connections as if I open a connection then complete a
 describe schema and close the connection repeatedly sometimes the XLS is
 then locked.
  Crispin
Ticket URL: <http://trac.osgeo.org/fdo/ticket/501>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
