[fdo-trac] #510: FDO Schema Writer bases gml:AbstractFeatureType on itself
FDO trac_fdo at osgeo.org
Tue Apr 21 08:52:10 EDT 2009
   Reporter:  brentrobinson  |       Owner:  brentrobinson
       Type:  defect         |      Status:  new
   Priority:  minor          |   Milestone:  3.5.0
  Component:  FDO API        |     Version:  3.5.0
   Severity:  3              |    Keywords:  FDO XML Schema writer AbstractFeatureType infinite recursion
External_id:                 |
 The following code:
     FdoFeatureSchemasP schemas = FdoFeatureSchemaCollection::Create(NULL);
     FdoFeatureSchemasP schemas2 =
     FdoXmlFlagsP flags = FdoXmlFlags::Create(
         L"",
         FdoXmlFlags::ErrorLevel_VeryLow
     FdoXmlReaderP gmlReader = FdoGml212Schema::CreateReader();
     schemas->ReadXml( gmlReader, flags );
     // Write the schema back to an XML document.
     schemas->WriteXml( L"schema_gml212a.xml", flags );
     schemas2 = FdoFeatureSchemaCollection::Create(NULL);
     schemas2->ReadXml( L"schema_gml212a.xml", flags );
 leads to an infinite recursion on the 2nd ReadXml. The problem is that
 WriteXML writes out gml:AbstractFeatureType as an extension of itself.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/510>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
