[fdo-trac] #510: FDO Schema Writer bases gml:AbstractFeatureType on itself
FDO trac_fdo at osgeo.org
Tue Apr 21 09:13:59 EDT 2009
 Reporter:  brentrobinson                                                 |         Owner:  brentrobinson
     Type:  defect                                                        |        Status:  closed
 Priority:  minor                                                         |     Milestone:  3.5.0
Component:  FDO API                                                       |       Version:  3.5.0
 Severity:  3                                                             |    Resolution:  fixed
 Keywords:  FDO XML Schema writer AbstractFeatureType infinite recursion  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 4561
 Author: brentrobinson
 Date: 8:54:24 AM, Tuesday, April 21, 2009
 Message:
 Ticket#510: prevent circular extension when writing
 gml:AbstractfeatureType to XML.
 Modified : /trunk/Fdo/UnitTest/SchemaTest.cpp
 Modified : /trunk/Fdo/UnitTest/SchemaTest.h
 Modified : /trunk/Fdo/UnitTest/schema_ext1.xml
 Modified : /trunk/Fdo/UnitTest/schema_ext_a_master.txt
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromInternal.h
 Modified : /trunk/Fdo/Unmanaged/Src/Fdo/Schema/SchemaFromInternal.xslt
Ticket URL: <http://trac.osgeo.org/fdo/ticket/510#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
