[fdo-trac] #595: MySQL: Fix setting of specific geometry types.
FDO trac_fdo at osgeo.org
Tue Dec 1 15:47:52 EST 2009
 Reporter:  brentrobinson                 |         Owner:  brentrobinson
     Type:  defect                        |        Status:  closed
 Priority:  minor                         |     Milestone:  3.5.0
Component:  FDO API                       |       Version:  3.5.0
 Severity:  3                             |    Resolution:  fixed
 Keywords:  MySQL Specific Geometry Type  |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 5116
 Author: brentrobinson
 Date: 3:29:55 PM, Tuesday, December 01, 2009
 Message:
 Ticket#595: Modified the setting of the specific geometry types, for a
 Geometric Property reverse-engineered from a MySQL geometry column in a
 datastore without FDO metadata. Previously, they were set to
 FdoGeometryType_MultiGeometry. With this change, they are set to the
 following list:
         FdoGeometryType_Point
         FdoGeometryType_MultiPoint
         FdoGeometryType_LineString
         FdoGeometryType_MultiLineString
         FdoGeometryType_Polygon
         FdoGeometryType_MultiPolygon
 Modified :
 /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColTypeMapper.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColTypeMapper.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.h
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt
Ticket URL: <http://trac.osgeo.org/fdo/ticket/595#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
