[fdo-trac] #586: SHP provider only does SHP compression in the destructor of last live SHP connection.
FDO trac_fdo at osgeo.org
Tue Dec 1 20:21:17 EST 2009
connection.
 Reporter:  StevenXu      |         Owner:  StevenXu
     Type:  defect        |        Status:  closed
 Priority:  major         |     Milestone:  3.5.0
Component:  SHP Provider  |       Version:  3.4.0
 Severity:  3             |    Resolution:  fixed
 Keywords:                |   External_id:  1247249
Changes (by StevenXu):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 However, this fix is fewer aggressive than Dan's idea by refining the
 granularity of ref counter to !ShpFileSet , that means, the reference
 counter
 std::map was used against every opened file set rather than every opened
 SHP
 connection.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/586#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
