[fdo-trac] #602: WMS: Fix
FDO trac_fdo at osgeo.org
Wed Dec 16 13:29:48 EST 2009
#602: WMS: Fix
   Reporter:  gregboone   |       Owner:  gregboone
       Type:  defect      |      Status:  new
   Priority:  major       |   Milestone:  3.5.0
  Component:  FDO API     |     Version:  3.4.0
   Severity:  2           |    Keywords:
External_id:  1203481.02  |
 Issues:
 - The WMS Class name returned from FDO has a trailing space character.
 This caused a subsequent failure. This error can be resolved by stripping
 off the trailing space before the schema is returned from FDO.
 - Applications are crashing in the FDO WMS provider accessing the schema
 class definition on the FDO Select statement. It looks as if the cached
 class definition is being released prematurely, and then re-accessed
 causing an exception. I believe
 tighter reference counting of FDO objects in the WMS provider will resolve
 this issue.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/602>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
