[fdo-trac] #452: GetClassNames does not work with ODBC Provider, SQL Server datasource
FDO trac_fdo at osgeo.org
Mon Feb 2 10:35:11 EST 2009
 Reporter:  brentrobinson                  |         Owner:  brentrobinson
     Type:  defect                         |        Status:  closed
 Priority:  major                          |     Milestone:
Component:  FDO API                        |       Version:  3.4.0
 Severity:  1                              |    Resolution:  fixed
 Keywords:  ODBC SQL Server GetClassNames  |   External_id:
Changes (by brentrobinson):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Revision: 4366
 Author: brentrobinson
 Date: 10:29:24 AM, Monday, February 02, 2009
 Message:
 Ticket#452: Modified FdoSmLpSchemaCollection::GetClassNames() to call
 FdoSmLpSchema::GetPhysicalOwner() to get the owner for finding classes for
 each FDO Feature Schema. Created GetPhysicalOwner() with default
 implementation that gets the default owner. The ODBC-specific
 implementation gets the owner with same name as the feature schema when
 schema is not the default schema and no config doc is used. This was
 needed because, when the ODBC provider connects to a SQL Server
 datasource, it maps each SQL Server schema in the datastore to a different
 FdmSmPhOwner, and each owner to an FDO Feature Schema.
 Modified : /trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/ODBC/SchemaMgr/Lp/Schema.h
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Lp/Schema.h
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/Schema.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/452#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
