[fdo-trac] #459: Update DLL version info for FDO components
FDO trac_fdo at osgeo.org
Wed Feb 11 03:47:19 EST 2009
 Reporter:  waltweltonlair  |         Owner:  waltweltonlair
     Type:  defect          |        Status:  closed
 Priority:  minor           |     Milestone:  3.4.0
Component:  General         |       Version:  3.4.0
 Severity:  2               |    Resolution:  fixed
 Keywords:                  |   External_id:  1197202
Comment (by waltweltonlair):
 An additional problem is that the !FileVersion field is not being updated
 for the 32-bit build.  This is because the field doesn't have enough
 characters for the !StampVer utility to set a version of the form
 3.4.0.xxxx.  The !FileVersions stored in the resource files currently look
 like 3.4.0.00.  To fix the problem they simply need to be changed to
 3.4.0.0000.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/459#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
