[fdo-trac] #464: SQLServerSpatialProvider thows an exception when GetPropertyCount is called from an aggregate reader
FDO trac_fdo at osgeo.org
Fri Feb 20 15:02:15 EST 2009
   Reporter:  romicadascalescu   |       Owner:  danstoica
       Type:  defect             |      Status:  new
   Priority:  major              |   Milestone:
  Component:  SQLServer Spatial  |     Version:  3.4.0
   Severity:  3                  |    Keywords:
External_id:                     |
 called from an aggregate reader.
 The issue is in following files:
 \\Providers\GenericRdbms\Src\SQLServerSpatial\Fdo\FdoRdbmsSqlServerOptimizedAggregateReader.h
 \\Providers\GenericRdbms\Src\Fdo\FeatureCommands\FdoRdbmsFeatureReader.h
 FdoRdbmsSqlServerOptimizedAggregateReader has following methods declared
 virtual
 public:
  virtual FdoInt32  GetPropertyCount();
  virtual FdoString*  GetPropertyName(FdoInt32 index);
  virtual FdoDataType  GetDataType(FdoString* idName);
  virtual FdoPropertyType GetPropertyType(FdoString* idName);
 FdoRdbmsFeatureReader has following methods declared non-virtual
 private:
     // This is an internal method to support the DataReader
     FdoDataType GetDataType(FdoString* propertyName);
     FdoPropertyType GetPropertyType(FdoString* propertyName);
 Since FdoRdbmsSqlServerOptimizedAggregateReader is derivate from
 FdoRdbmsFeatureReader when we call a from a
 FdoRdbmsSqlServerOptimizedAggregateReader object one of those methods, we
 will calle methods from FdoRdbmsFeatureReader because methods are not
 virtual
Ticket URL: <http://trac.osgeo.org/fdo/ticket/464>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
