[fdo-trac] #449: SHP provider capability SupportsParameters() is incorrect
FDO trac_fdo at osgeo.org
Fri Jan 16 09:16:35 EST 2009
   Reporter:  jng           |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.4.0
  Component:  SHP Provider  |     Version:  3.4.0
   Severity:  3             |    Keywords:
External_id:                |
 Currently the SHP provider returns false for the SupportParameters()
 capability.
 But look at the unit tests, and you will see clear usage of FdoParameter
 objects for batch inserts, so this is clearly not the case.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/449>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
