[fdo-trac] #450: Expression Function SUBSTR does not work as expected
FDO trac_fdo at osgeo.org
Fri Jan 16 16:58:43 EST 2009
 Reporter:  thomasknoell  |         Owner:  thomasknoell
     Type:  defect        |        Status:  closed
 Priority:  major         |     Milestone:
Component:  FDO API       |       Version:  3.4.0
 Severity:  3             |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by thomasknoell):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 The fix affected the following open-source files:
 Providers\GenericRdbms\Src\UnitTest\Common\FdoExpressionFunctionTest.cpp
 Providers\GenericRdbms\Src\UnitTest\Common\FdoExpressionFunctionTest.h
 Modified: Providers\SDF\Src\UnitTest\FdoExpressionFunctionTest.cpp
 Modified: Providers\SDF\Src\UnitTest\FdoExpressionFunctionTest.h
 Modified: Providers\SHP\Src\UnitTest\FdoExpressionFunctionTest.cpp
 Modified: Providers\SHP\Src\UnitTest\FdoExpressionFunctionTest.h
 Utilities\ExpressionEngine\Inc\Functions\String\FdoFunctionSubstr.h
 Utilities\ExpressionEngine\Src\Functions\String\FdoFunctionSubstr.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/450#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
