[fdo-trac] #530: Connections with PostGIS versions > 1.3.4 do not work
FDO trac_fdo at osgeo.org
Fri Jun 5 20:05:16 EDT 2009
   Reporter:  mwtoews           |       Owner:
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.5.0
  Component:  PostGIS Provider  |     Version:  3.4.0
   Severity:  3                 |    Keywords:
External_id:                    |
 Connecting to a PostGIS server versions 1.3.5 and 1.3.6 do not work with
 the FDO providers versions 3.2 and 3.4. With AutoCAD Map3D 2008, a full
 crash with "AutoCAD cannot continue", and with Map3D 2010 an exception is
 thrown "There was a problem accessing the connection's schema
 information."
 Unit tests on an Ubuntu Hardy 8.04 server have the results:
  * postgis-1.3.3 (2008/04/12) - works with FDO
  * postgis-1.3.4 (2008/11/24) - works with FDO
  * postgis-1.3.5 (2008/12/15) - doesn't work with FDO
  * postgis-1.3.6 (2009/05/04) - doesn't work with FDO
 For these unit tests, versions of geos (3.1.0-CAPI-1.5.0) and proj (4.6.1)
 were held constant. All testing was done using modules manually build from
 source using default options in ./configure .
 Support for recent stable versions of PostGIS would be appreciated.
 See also http://lists.osgeo.org/pipermail/fdo-users/2009-June/001665.html
Ticket URL: <https://trac.osgeo.org/fdo/ticket/530>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
