[fdo-trac] #537: Fix MySQLFdoApplySchemaTest.TestOverride
FDO trac_fdo at osgeo.org
Thu Jun 25 15:58:51 EDT 2009
 Reporter:  brentrobinson                                   |         Owner:  brentrobinson
     Type:  defect                                          |        Status:  closed
 Priority:  minor                                           |     Milestone:  3.5.0
Component:  MySQL Provider                                  |       Version:  3.5.0
 Severity:  3                                               |    Resolution:  fixed
 Keywords:  MySQLFdoApplySchemaTest.TestOverride unit test  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 4814
 Author: brentrobinson
 Date: 3:57:46 PM, Thursday, June 25, 2009
 Message:
 ticket#537: Fixed the MySQLFdoApplySchemaTest.TestOverrides test, which
 was failing with:
 RDBMS: Invalid default value for 'featid'
 The reason is that if the following is done in MySQL:
 create table table1 ( id bigint auto_increment, val nvarchar(10), primary
 key (id);
 create view view1 as select * from table1;
 desc view1;
 view1.id will be shown as having a default value of 0.
 In the unit test, ovclassh is a view. Similar to the above, MySQL reports
 ovclassh.featid as having a default value of 0, but the FDO MetaData
 indicates that it is autoincremented.
 The unit test the creates an ovclassh1, based on ovclassh. This fails
 because the provider tries to create an ovclassh1.featid column that is
 autoincremented and has a default value.
 The fix was to ignore default value when reverse-engineering a column into
 an autoincremented property.
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/537#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
