[fdo-trac] #472: Move FDO .NET from old CLR syntax to the new CLR syntax
FDO trac_fdo at osgeo.org
Fri Mar 6 12:00:56 EST 2009
   Reporter:  romicadascalescu  |       Owner:  gregboone
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.4.0
  Component:  FDO API           |     Version:  3.4.0
   Severity:  4                 |    Keywords:
External_id:                    |
 FDO .NET still uses the old syntax, we should change the FDO .NET to use
 the new syntax.
 This will improve the API since and all destructors will be called.
 The changes will be in sandbox to allow users to test them.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/472>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
