[fdo-trac] #481: Extend FdoIDataReader to provide raw access to current geometry
FDO trac_fdo at osgeo.org
Fri Mar 20 15:17:54 EDT 2009
   Reporter:  waltweltonlair  |       Owner:  gregboone
       Type:  defect          |      Status:  new
   Priority:  minor           |   Milestone:  3.5.0
  Component:  FDO API         |     Version:  3.4.0
   Severity:  3               |    Keywords:
External_id:                  |
 The FdoIFeatureReader interfaces provides the following method which gives
 raw access to the current geometry pointed to by the reader:
     FDO_API virtual const !FdoByte * !GetGeometry(!FdoString*
 propertyName, !FdoInt32 * count) = 0;
 For performance reasons the FdoIDataReader interface should provide the
 same method.  Currently with FdoIDataReader, the only way to obtain the
 geometry is via the following FdoIReader method:
     FDO_API virtual !FdoByteArray* !GetGeometry(!FdoString* propertyName)
 = 0;
 which allocates a copy of the data.  Callers then have a choice of which
 method to call, depending on their context.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/481>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
