[fdo-trac] #476: GeometricPropertyDefinition get_SpecificGeometryTypes() not exposed in managed API
FDO trac_fdo at osgeo.org
Tue Mar 24 19:26:05 EDT 2009
managed API
 Reporter:  jng      |         Owner:  gregboone
     Type:  defect   |        Status:  assigned
 Priority:  major    |     Milestone:  3.5.0
Component:  FDO API  |       Version:  3.4.0
 Severity:  3        |    Resolution:
 Keywords:           |   External_id:
Changes (by gregboone):
  * milestone:  3.4.0 => 3.5.0
Comment:
 In class GeometricPropertyDefinition, we are not really exposing
 SpecificGeometryTypes as a standard property.
 Currently, SpecificGeometryTypes is defined as a property but it is being
 generated as two methods: get_SpecificGeometryTypes and
 set_SpecificGeometryTypes. This is happening because the property is
 defined with two parameters, 'length' and 'array'. Managed properties are
 intended to only have a single parameter, in this instance, the array. The
 length can be determined directly though the array itself by querying the
 arrays Length property.
 As a result of this change, the length parameter will be removed and the
 property defined as:
     property array<NAMESPACE_OSGEO_COMMON::GeometryType>^
         array<NAMESPACE_OSGEO_COMMON::GeometryType>^ get();
         System::Void set(array<NAMESPACE_OSGEO_COMMON::GeometryType>^
 types);
Ticket URL: <http://trac.osgeo.org/fdo/ticket/476#comment:7>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
