[fdo-trac] #488: Managed API: Managned Exception Constructor returns null
FDO trac_fdo at osgeo.org
Mon Mar 30 12:31:38 EDT 2009
 Reporter:  gregboone  |         Owner:  gregboone
     Type:  defect     |        Status:  new
 Priority:  minor      |     Milestone:  3.5.0
Component:  FDO API    |       Version:  3.4.0
 Severity:  3          |    Resolution:
 Keywords:             |   External_id:  1209691
Old description:
> Modify the implementation of
>     NAMESPACE_OSGEO_COMMON::Exception::Create(System::IntPtr ex)
> - Change the if (IntPtr::Zero == ex) check to: if (IntPtr::Zero != ex)
> - Have a single return point in the function
> - Avoid trying to create a nested NAMESPACE_OSGEO_COMMON::Exception
> object for
> the nested FDO exception if the nested FDO cause exception is NULL
> - Add a try...catch block so that this method does not throw errors.
New description:
 - Avoid trying to create a nested NAMESPACE_OSGEO_COMMON::Exception object
 for the nested FDO exception if the nested FDO cause exception is NULL
Ticket URL: <http://trac.osgeo.org/fdo/ticket/488#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
