[fdo-trac] #583: SQLServerSpatial: Prevent adding system columns to existing tables
FDO trac_fdo at osgeo.org
Wed Nov 11 09:31:38 EST 2009
 Reporter:  brentrobinson                                 |         Owner:  brentrobinson
     Type:  defect                                        |        Status:  assigned
 Priority:  minor                                         |     Milestone:  3.5.0
Component:  FDO API                                       |       Version:  3.4.0
 Severity:  3                                             |    Resolution:
 Keywords:  SQLServerSpatial Apply Schema existing table  |   External_id:
Comment (by brentrobinson):
 Revision: 5069
 Author: brentrobinson
 Date: 9:29:14 AM, Wednesday, November 11, 2009
 Message:
 Ticket#583: Modified ApplySchema to skip adding system columns to existing
 tables, since the user did not
 explicitly ask for them.
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_foreign_out2_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides3_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out1_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_overrides_out2_master.txt
 Modified :
 /trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/583#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
