[fdo-trac] #565: WFS: Provider does not set FeatureClass Capabilities
FDO trac_fdo at osgeo.org
Thu Oct 1 17:00:26 EDT 2009
 Reporter:  gregboone     |         Owner:  gregboone
     Type:  defect        |        Status:  assigned
 Priority:  minor         |     Milestone:  3.5.0
Component:  WFS Provider  |       Version:  3.4.0
 Severity:  3             |    Resolution:
 Keywords:                |   External_id:  1087759
Changes (by gregboone):
  * status:  new => assigned
Old description:
> When constructing the WFS class definitions in
> FdoWfsConnection::GetSchemas(), the classes that are defined are not
> constructed with Class Capabilities
> The following code block needs to be added to the function.
> // Perform 6. Set Class capabilities
> FdoPtr<FdoClassCapabilities> classCaps = classDef->GetCapabilities();
> if (NULL == classCaps)
>     // Create the class capabilities.
>     classCaps = FdoClassCapabilities::Create(*classDef.p);
>     classCaps->SetSupportsLocking(false);
>     classCaps->SetSupportsLongTransactions(false);
>     classCaps->SetSupportsWrite(false);
>     // Set the class capabilities
>     classDef->SetCapabilities(classCaps);
New description:
 FdoWfsConnection::!GetSchemas(), the classes that are defined are not
Ticket URL: <http://trac.osgeo.org/fdo/ticket/565#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
