[fdo-trac] #552: Managed StringElement garbles the .net string assigned to it
FDO trac_fdo at osgeo.org
Tue Oct 6 09:55:44 EDT 2009
 Reporter:  jng       |         Owner:  gregboone
     Type:  defect    |        Status:  new
 Priority:  critical  |     Milestone:
Component:  FDO API   |       Version:  3.4.0
 Severity:  1         |    Resolution:
 Keywords:            |   External_id:
Changes (by jng):
  * component:  GenericRdbms API => FDO API
  * summary:  ODBC provider garbles the specified class name when using
              enhanced IDescribeSchema => Managed
              to it
Comment:
 In writing the attached sample code, I've discovered that the
 StringElement wrapper class is quite possibly the culprit here.
 When you feed a .net string to a new StringElement instance, inspecting
 the String property (StringElement.String) returns a garbled version of
 the original string.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/552#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
