[fdo-trac] #575: Out-of-memory exception is not handled very well in FdoArrayHelper::AllocMore(...)
FDO trac_fdo at osgeo.org
Tue Oct 27 23:15:12 EDT 2009
   Reporter:  Wesley      |       Owner:  Wesley
       Type:  defect      |      Status:  new
   Priority:  major       |   Milestone:  3.5.0
  Component:  FDO API     |     Version:  3.4.0
   Severity:  1           |    Keywords:  Out-of-memory exception crash
External_id:  1269041.01  |
 In FdoArrayHelper::AllocMore(..), the following code is used to allocate
 more
 memory.
   if (NULL == newArray)
             newArray = (GenericArray*) new FdoByte[newAllocBytes];
         if (0==newArray)
                 throw
 FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID
 (FDO_1_BADALLOC)));
 If there is no enough memory, an out-of-memory exception will be thrown
 while
 using operator "new". Since this exception is not caught, the next IF
 statement
 will not work and application may crash.
 FdoArrayHelper::AllocMore(...) is a public API. Therefore, when it is used
 to
 allocate large memory, it is likely to cause crash.
 To fix it, catching any exception and depending on the next statement to
 verify
 if it fails or not, that is enough.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/575>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
