[fdo-trac] #578: SDF: Add/Delete property does not remove the deleted property
FDO trac_fdo at osgeo.org
Fri Oct 30 14:01:47 EDT 2009
   Reporter:  romicadascalescu  |       Owner:  romicadascalescu
       Type:  defect            |      Status:  new
   Priority:  minor             |   Milestone:  3.5.0
  Component:  FDO API           |     Version:  3.5.0
   Severity:  3                 |    Keywords:
External_id:                    |
 - Create a new SDF with: Id, Geom, Name properties, apply it.
  - Describe the schema add a new property Description and delete Name, re-
 apply the schema.
 The Name will not be deleted.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/578>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
