[fdo-trac] #638: SQLServerSpatial: memory leaks in FdoIUpdate
FDO trac_fdo at osgeo.org
Wed Apr 7 12:22:27 EDT 2010
 Reporter:  brentrobinson                            |         Owner:  brentrobinson
     Type:  defect                                   |        Status:  closed
 Priority:  major                                    |     Milestone:  3.6.0
Component:  SQLServer Spatial                        |       Version:  3.5.0
 Severity:  2                                        |    Resolution:  fixed
 Keywords:  SQLServerSpatial FdoIUpdate memory leak  |   External_id:
Changes (by brentrobinson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Revision: 5453
 Author: brentrobinson
 Date: 12:17:27 PM, Wednesday, April 07, 2010
 Message:
 Ticket#638: memory leak fixes:
 FdoRdbmsPvcUpdateHandler - free bound geometries after update is executed
 LockUtility - free an allocated string
 odbcdr_execute_direct - free the statement handle after the sql has been
 executed.
 Modified : /trunk/Providers/GenericRdbms/Src/Fdo/Lock/LockUtility.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/ODBCDriver/execute_direct.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/SQLServerSpatial/ODBCDriver/execute_direct.c
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoDeleteTest.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/638#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
