[fdo-trac] #640: Find FDOMessage.cat without having to set NLSPATH
FDO trac_fdo at osgeo.org
Thu Apr 15 12:49:36 EDT 2010
   Reporter:  tomfukushima  |       Owner:  gregboone
       Type:  enhancement   |      Status:  new
   Priority:  minor         |   Milestone:  3.6.0
  Component:  General       |     Version:  3.5.0
   Severity:  3             |    Keywords:
External_id:                |
 On Linux, FDO needs the NLSPATH environment variable to be set before it
 can find the FDOMessage.cat file for messages.  If this variable is not
 set messages such as CLNT_4_PROVIDERNOTREGISTERED are produced; if it is
 set then the message “FDO Provider Not Registered” is returned as the
 exception message.
 This enhancement is to change the behavior so that if NLSPATH is not set,
 then FDO would look in <FDO install directory>/nls for the FDOMessage.cat
 file.
 Hopefully, this is possible.  Also, I'm not sure if the same problem
 exists on Windows, but it doesn't seem to (so perhaps this is actually a
 defect).
Ticket URL: <http://trac.osgeo.org/fdo/ticket/640>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
