[fdo-trac] #680: SHP: ApplySchema will not set the correct class capabilities if adding a new feature class
FDO trac_fdo at osgeo.org
Mon Aug 16 21:48:15 EDT 2010
new feature class
   Reporter:  leaf          |       Owner:  gregboone
       Type:  defect        |      Status:  new
   Priority:  major         |   Milestone:  3.6.0
  Component:  SHP Provider  |     Version:  3.4.0
   Severity:  3             |    Keywords:
External_id:                |
 1. Use ApplySchema command to add a new feature class for a SHP file.
 2. Descirbe schema to get class defintion of the newly created feature
 class.
 3. Get class capabilities of this feature class.
 Result:
 1. If you didn't set class capabilites of the newly added feature class in
 the first step, the result gotten in third step will be null.
 2. If you didn't set class capabilites of the newly added feature class in
 the first step, the result gotten is same as the class capabilites you
 set.
 Expected:
 1. Class capabilities should be always returned no matter users set it or
 not when executing ApplySchema command.
 2. Class capabilities should not be same as value that users set when
 executing ApplySchema command because users may set the wrong value for
 class capabilities. For example, set SetSupportsLongTransactions true.
 However, SHP doesn't support it.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/680>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
