[fdo-trac] #612: SQLite - Handle read-only files and multiple properties with same name in SQL command
FDO trac_fdo at osgeo.org
Wed Feb 10 12:15:16 EST 2010
SQL command
   Reporter:  romicadascalescu  |       Owner:  romicadascalescu
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.5.0
  Component:  SQLite Provider   |     Version:  3.5.0
   Severity:  4                 |    Keywords:
External_id:                    |
 SQLite throws exceptions late when user tries to insert/update/delete
 features.
 SQLite should expose read only in capabilities of the class
 (GetSupportsWrite/SetSupportsWrite).
 Handle SQL commands like "select Id as col1, Val+55 as col1 from tab" by
 generating new names for second name found.
 This change is meant for 3.6, however Version and Milestone is not updated
 yet.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/612>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
