[fdo-trac] #662: Bug in FdoFilter::ToString
FDO trac_fdo at osgeo.org
Wed Jul 14 05:45:54 EDT 2010
   Reporter:  ijarm    |       Owner:  gregboone
       Type:  defect   |      Status:  new
   Priority:  minor    |   Milestone:  3.5.0
  Component:  FDO API  |     Version:  3.4.0
   Severity:  1        |    Keywords:  FDO FdoFilter ToString Parse parsing bug defect
External_id:           |
 An FdoFilter representing NOT(a AND b) returns L"NOT a AND b" when its
 ToString is called.
 This code:
 FdoFilter *NOTaANDb;//NOT(a AND b)
 FdoFilter *newFlt = FdoFilter::Parse(NOTaANDb->ToString());
 makes newFlt that is not equal to the original.
 I tested this in FDO 3.4 but as far as I could see parsing code in FDO 3.5
 hasn't changed at all.
 The following is a sample code used to produce the error:
 //a
   FdoPtr<FdoFilter> flt1 = FdoFilter::Parse(L"Geometry INTERSECTS
 GeomFromText('POLYGON ((461848 100030, 462399 100892, 463039 100544,
 462697 99882, 462545 99926, 462652 100525, 462539 100612, 462075 99911,
 461848 100030))')");
 //b
   FdoPtr<FdoFilter> flt2 = FdoFilter::Parse(L"POVRSINA < 200");
 //a AND b
   FdoPtr<FdoFilter> fltand = FdoFilter::Combine(flt1,
 FdoBinaryLogicalOperations_And, flt2);
 //NOT(a AND b)
   FdoPtr<FdoFilter> fltnot = FdoUnaryLogicalOperator::Create(fltand,
 FdoUnaryLogicalOperations_Not);
 //the same filter can be parsed directly from string
 //  fltnot = FdoFilter::Parse(L"NOT(Geometry INTERSECTS
 461848 100030))') AND POVRSINA < 200)");
 //WRONG: filterStr equals L"NOT Geometry INTERSECTS GeomFromText('POLYGON
 ((461848 100030, 462399 100892, 463039 100544, 462697 99882, 462545 99926,
 462652 100525, 462539 100612, 462075 99911, 461848 100030))') AND POVRSINA
 < 200"
 //SHOULD BE: L"NOT ( Geometry INTERSECTS GeomFromText('POLYGON ((461848
 100030, 462399 100892, 463039 100544, 462697 99882, 462545 99926, 462652
 100525, 462539 100612, 462075 99911, 461848 100030))') AND POVRSINA < 200
   FdoString *filterStr = fltnot->ToString();
Ticket URL: <http://trac.osgeo.org/fdo/ticket/662>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
