[fdo-trac] #663: SQLite improvements for Spatial Index better update detection
FDO trac_fdo at osgeo.org
Fri Jul 16 15:54:28 EDT 2010
   Reporter:  romicadascalescu  |       Owner:  romicadascalescu
       Type:  enhancement       |      Status:  new
   Priority:  major             |   Milestone:  3.6.0
  Component:  SQLite Provider   |     Version:  3.5.0
   Severity:  3                 |    Keywords:
External_id:                    |
 SQLite provider improvements:
  - provider could not 'see' updates of geometries between connection,
 leading to have multiple Spatial Index out of sync. This has been fixed by
 add an interface (a few plug-in functions) into sqlite engine which offers
 access to the Spatial Index
  - made some improvements in sqlite engine to avoid releasing the internal
 schema each time a connection opens or closes a certain file.
  - since the schema is shared between different connection against the
 same file now Spatial Index will be the same shared, this way we avoid
 having multiple Spatial Indexes for different connections. This will help
 a lot Map Guide by not loading Spatial Indexes as many connections we
 have.
  - added new tests with multiple connection writing on them (not in the
 same time) and making selects to see if changes are visible between
 connections. - removed hook functions which fired for every update in
 database to avoid performance problems.
  - enabled some spatial multi-thread tests commented out because SQLite
 provider got out of sync Spatial Indexes between connections
Ticket URL: <http://trac.osgeo.org/fdo/ticket/663>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
