[fdo-trac] #654: GDAL FDO does not handle rotate images
FDO trac_fdo at osgeo.org
Tue Jun 8 12:58:40 EDT 2010
 Reporter:  andrewd        |         Owner:  warmerdam
     Type:  defect         |        Status:  assigned
 Priority:  major          |     Milestone:  3.6.0
Component:  GDAL Provider  |       Version:  3.4.0
 Severity:  3              |    Resolution:
 Keywords:                 |   External_id:
Comment (by warmerdam):
 Warping is available in GDAL using the warp api referenced above, but this
 is not exposed via the FDO GDAL provider.  I would be using that warp api
 in a very simplified case to do the rotation.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/654#comment:3>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
