[fdo-trac] #699: RDBMS: Fixes for classes with inherited associations and constraints
FDO trac_fdo at osgeo.org
Thu Oct 7 08:54:28 EDT 2010
 Reporter:  brentrobinson                                              |         Owner:  brentrobinson
     Type:  defect                                                     |        Status:  closed
 Priority:  minor                                                      |     Milestone:  3.6.0
Component:  GenericRdbms API                                           |       Version:
 Severity:  3                                                          |    Resolution:  fixed
 Keywords:  Association Property List Constraint inherited base class  |   External_id:
Comment(by brentrobinson):
 Revision: 5682
 Author: brentrobinson
 Date: 2:49:50 PM, Friday, September 24, 2010
 Message:
 Ticket#669:
 FdoSmPhRdPostGisConstraintReader:corrected left/right bracket imbalance
 resulting from conversion of check constraint from PostGreSQL to FDO
 format.
 FdoSmLpAssociationProperty: there is a check to ensure that an assocation
 between the containing and associated classes does not already exist. This
 check is now performed only for new associations.
 Also, removed "text", "cascade" and "mode" as reserved words.
 Modified : /trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Mgr.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/PostGis/SchemaMgr/Ph/Rd/ConstraintReader.cpp
 Modified : /trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h
 Modified :
 /trunk/Utilities/SchemaMgr/Src/Sm/Lp/AssociationPropertyDefinition.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/699#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
