[fdo-trac] #694: Undefined symbols in libPostGISProvider-3.5.0.so
FDO trac_fdo at osgeo.org
Sat Sep 11 01:35:46 EDT 2010
   Reporter:  trevorwekel       |       Owner:  trevorwekel
       Type:  defect            |      Status:  new
   Priority:  blocker           |   Milestone:  3.5.0
  Component:  PostGIS Provider  |     Version:  3.5.0
   Severity:  1                 |    Keywords:  linux PostGIS PostgreSQL
External_id:                    |
 When the PostGIS Provider is build using configure/make, a number of
 undefined symbols appear when "ldd -r" is run on the .so file
 undefined symbol: PQclear       (./libPostGISProvider.so)
 undefined symbol: PQresultStatus        (./libPostGISProvider.so)
 undefined symbol: PQgetvalue    (./libPostGISProvider.so)
 undefined symbol: PQresultErrorMessage  (./libPostGISProvider.so)
 undefined symbol: PQexec        (./libPostGISProvider.so)
 undefined symbol: _ZN12FdoFunctionZ6CreateEv
 (./libPostGISProvider-3.5.0.so)
 undefined symbol: _ZN12FdoFunctionX6CreateEv
 undefined symbol: _ZN12FdoFunctionY6CreateEv
 undefined symbol: _ZN12FdoFunctionM6CreateEv
 The first block is due to damaged libpq.a and libecpg.a libraries checked
 into Subversion.  Libraries rebuild from the PostgreSQL 8.4.2 sources work
 ok.
 The second block is due to a missing libExpressionEngine library
 dependency in Providers/PostGIS/Src/Makefile.am.  Adding the missing
 dependency to Makefile.am fixes the issue.
 The undefined symbols prevent the PostGIS library from loading
 successfully on Linux.  The first block of undefined symbols also causes
 load errors with the PostgreSQL provider.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/694>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
