[fdo-trac] #802: mUseNesting is not right
FDO trac_fdo at osgeo.org
Mon Dec 12 03:33:18 EST 2011
   Reporter:  ChristineBao   |       Owner:  thomasknoell
       Type:  defect         |      Status:  new
   Priority:  critical       |   Milestone:  3.7.0
  Component:  ODBC Provider  |     Version:  3.7.0
   Severity:  2              |    Keywords:
External_id:                 |
Comment(by ChristineBao):
 Hi Thomas,
    I read your fixing in ticket #367 (r4030) which fixed the nested "("
 issue in some cases. I don't think the necessaries to add additional "("
 in the filter, so I remove the mUseNesting flag. It's tested successfully
 in this test case, however I am not sure how it works for others. Would
 you please review it?
    This defect cause MapGuide cannot select features if use ODBC provider.
 It's appreciated that you can review it in this week.
 Thanks & regards,
 Christine
Ticket URL: <http://trac.osgeo.org/fdo/ticket/802#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
