[fdo-trac] #737: SHP provider: Allow ':' characters in property name
FDO trac_fdo at osgeo.org
Thu Jan 13 11:56:38 EST 2011
 Reporter:  danstoica     |         Owner:  Dan Stoica
     Type:  enhancement   |        Status:  closed
 Priority:  major         |     Milestone:  3.6.0
Component:  SHP Provider  |       Version:  3.5.0
 Severity:  2             |    Resolution:  fixed
 Keywords:                |   External_id:
Comment(by gregboone):
 The following change sets illustrate the changes made in the SHP provider
 to allow DBF files that have columns containing ":" and "." to be read and
 processed by FDO
 http://trac.osgeo.org/fdo/changeset/5858
 http://trac.osgeo.org/fdo/changeset/5859
 If ":" or "." are found, these characters are replaced by "_" when the DBF
 Physical schema is read and exposed as logical FDO Schema. Thus columns
 that are physically defined as a:b will be exposed logically as a_b.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/737#comment:7>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
